It`s a THING!!!
  • Airborne01
    • Mar 2021
    • 4035
    • Steve
    • Essex
    #31
    Jakko,
    Reference your last. Just checked that build - excellent! Thanks for that!
    No idea Jakko - if he was he probably suffers from hearing loss as well!
    • rtfoe
      • 9121
      #32
      Imagine killing the enemy at both ends...similar to a burp and fart happening simultaneously. :tears-of-joy::smiling6:
      • Airborne01
        • Mar 2021
        • 4035
        • Steve
        • Essex
        #33
        Doesn't bear thinking about - have you seen the price of Y-fronts lately?
        • The Smythe Meister
          • Jan 2019
          • 6248
          #34
          Originally posted by minitnkr
          At first glance thought it was your result:surprised:.
          HA!!..... I could take that as abuse Paul:dizzy: ,HOWEVER.......
          ....... in this case,that would`ve been a massive compliment!!:tears-of-joy::tears-of-joy::tears-of-joy:
          Andy
            • Jan 2019
            • 6248
            #35
            OOh, that was a bit sneaky, underhand, and positively brilliant mate! :smiling5:
            he he:hungry:!!...... Why thank you Sir,i do try!!
            Andy
              • Jan 2019
              • 6248
              #36
              Another minor problem with the Ontos, was that reloading the 6 barrels was done from outside the vehicle - a crew member had to dismount, & physically remove the spent cases & reload with fresh rounds - and the 106mm recoilless rifle rounds are larger than a 105mm howitzer round.................... This would mean the vehicle retiring & finding a safe place to reload, not something that would be easy to do in action
              [ATTACH=CONFIG]n1160099[/ATTACH]
              Interesting stuff there Dave,nice one:thumb2:,
              You`re right about the re-loading being a pain...... must`ve caused quite a few casualties if they were firing from an exposed position!:fearful:
              Andy
                • Jan 2019
                • 6248
                #37
                Originally posted by adt70hk
                What he said!!!
                Cheers Andrew:smiling5:!
                I know what you mean..... that re-loading scenario is a shocker eh?!!:surprised:
                Andy
                  • Jan 2019
                  • 6248
                  #38
                  Back in the day we fired Wombat, Mobat and Combat - all similar beasts, albeit single barrels - and I can attest to their ferocious backblast! Even the Carl Gustav and 66mm LAW can clear the leaves for quite some distance to the rear!! Definitely a filler of Y-fronts for the unitiated! :face-with-head-bandage:
                  I`m quite envious of you getting to use those toys in the ARMY Steve,........
                  ........ all i got to do was play with Nimrods,Tornados and Phantoms on the ground in my RAF days:sad:,
                  Andy
                    • Jan 2019
                    • 6248
                    #39
                    Count me in. Looking forward to this.
                    Great to see you look in Scottie(Dawg!!):thumb2:,
                    Welcome aboard!
                    Andy
                      • Jan 2019
                      • 6248
                      #40
                      Originally posted by Jakko
                      Shall I be a spoilsport and point out that the ones on the left side are still in their proper alignment? :smiling3:
                      Wasnโ€™t Mike C (Isitme) a WOMBAT crew member at some point? I think he mentioned that when he built a model of a Land Rover with one on here some time ago.
                      That`s not being a spoil sport Jakko! I had noticed that,but whether mine will be in such "Good" nick after it`s demise is yet to be decided!!
                      Andy
                        • Jan 2019
                        • 6248
                        #41
                        A`noon Guys,
                        Well,i must admit that i`m amazed by the interest that this has generated..... it`s pretty cool though!!:thumb2:
                        There`s not a lot to report as the amount of tiny bits fitted already don`t add much to the look of it,but this "Thing" is so T EYE KNEE .........
                        The figure is just there for size...... and NO..... he`s not one of the pair that came with the kit!!:smiling5:
                        Andy
                        • Airborne01
                          • Mar 2021
                          • 4035
                          • Steve
                          • Essex
                          #42
                          Andy
                          Lots of other toys too Andy, whole tranche of weapon types; things that go bang, Claymores, sneaky things etc etc - even a simulated atomic explosion on the NBC Instructors course! Mind you, they pale into insignificance beside fully tooled up wingy things that you mention!
                          Steve:flushed:
                          • minitnkr
                            • 7574
                            • Dayton, OH USA
                            #43
                            Less likely to bog down than M48s due to much lighter ground pressure, so could provide arty support most anywhere. Small & maneuverable, was very effective at Hue.
                              • Jan 2019
                              • 6248
                              #44
                              Indeed Paul,
                              I saw a short clip on the net of one of these firing across a river at an emplacement,and you see a plume of earth/dust/rubble errupt into the air ......
                              Shortly after the salvo impacted the crew commander jumps down..... runs a hundred yards or so to a group of watching troops. He must`ve asked if that was what they wanted because you can see him being told "Left a bit",(or words to that effect!!)...... he then sprints back to his Ontos and fires another salvo.....
                              .....this time there`s a much bigger explosion/erruption and you hear some whooping and cheering!!:thumb2::tears-of-joy::tears-of-joy:
                              It`s only a short and grainy clip,but well worth a watch!
                              Andy
                                • Jan 2019
                                • 6248
                                #45
                                Just found this instead..... it`s even better,but i suspect it`s from the same action!
